chevyx92
- VA BCH, VA
This section states that the conductor need not be larger than 6 AWG Copper or 4 AWG Aluminum wire. How can someone use aluminum wire and comply with this section without violating 250.64(A)?
chevyx92 said:This section states that the conductor need not be larger than 6 AWG Copper or 4 AWG Aluminum wire. How can someone use aluminum wire and comply with this section without violating 250.64(A)?
frizbeedog said:Keep it away from the dirt (18") and direct contact with masonry?
....and salt air environments would be bad?
chevyx92 said:The hard part of that is you can not terminate the wire within 18" of the earth. So no matter what you have to be at least that high above the ground.
frizbeedog said:Right.
I don't say that an Al. GEC is a good idea....it's just allowed to be used....if...
iwire said:How much you want to bet the 18" above grade rule went into the code long after 4 AWG AL had been in 250.66?
frizbeedog said:$1.00
I'm all ears.
:smile:
Dennis Alwon said:
chris kennedy said:Now there is the long weekend silliness I've been looking forward to.
3 day weekend and nobody censored and nothing deleted. You feeling OK Bob?iwire said:Yeah, it makes me proud to be a part of it. :roll:
chris kennedy said:3 day weekend and nobody censored and nothing deleted. You feeling OK Bob?
How about you Larry? Everything OK?
Is this like the blinking recessed-lights thread?acrwc10 said:Frizbeedog has spider eye's.
When he blinks do they all shut at once, or do they go across from left to right ?
