AKsparky1
- Anchorage, Alaska
I'm a little confused about when you can use building steel as a GEC. I have a steel conex sitting on timbers on the ground. I do not have a separately derived system in the conex but I do have a panel with an EGC in the feeder. Can I run a GEC from the panel to a beam inside the conex and then attach a GEC to the outside steel framing of the conex to bond the conex to an electrode or does the GEC need to be continuous?
