rubob
- Asheville North Carolina
250.68(C)(2) states that 'The metal structural frame of a building shall be permitted to be used as a conductor to interconnect electrodes that are part of the grounding electrode system, or as a grounding electrode conductor.' Does this not mean then that the building steel does not have to be a grounding electrode in order to be a conductor between electrodes? For instance, if I had a steel building that was not in direct contact with the earth for 10 ft. or more couldn't I still go from my service disconnect to the building steel and then 100 ft. away go from my building steel to within 5 ft of where my metal water pipe enters the building and be within the code?
