The use of GROUNDING and GROUNDED traditional use for neutral and equipment conductors leaves interpretive confusion under certain applications in the NEC. I am in the process of proposing that when these two references are used for the inference of path function differentiation that the text be in caps. The remaining verb references on grounding or grounded to remain in the lower case text. This will remove most of the confusion of figuring out which context of meaning is implied. Anyone have additional ideas? rbj
