starkmanelectric
New member
- New York
I'm doing work at a building where there is an existing 120/240 delta w/ hi leg system. The building now has the option to go 120/208 wye. This would be fine because they have very little 3-phase equipment and they are loosing 33% of their breaker spaces with the hi leg. My question; Will their existing equipment have problems? Most of their 2-pole single phase equip is rated for 240 volts. The only 3-phase unit that they have is rated for 230-volts. I don't see any multi-tap options on the motors. These are standard sanders and equipment that can be purchased at tool stores. Will this equipment run well on 208-volts without problems?
