tan_man
- United States
I have a lighting issue in a compressor building. The light fixtures are 250W HPS single phase 240VAC (seven fixtures total). They are located in a building adjacent to two (2) three horse power cooling fans. When these cooling fans turn on randomly, the light fixtures turn off and then slowly come back on automatically. Both fans do not usually turn on simultaneously. The fans are 3 phase 240VAC. I have not had the opportunity to check inrush current and voltage. I am wondering if installing VFDs for the cooling fans would be the best solution for the lighting issue. This issue never occurred until the fans were installed about a year ago. One fan motor has already burnt up and replaced since initial installation about a year ago. Thoughts?
Thank you for any input
