precise8128
- Memphis, TN
I have a project I am working on and I could use some help on determining what size KVA transformer I need to order. Here is what I got:
A 400A Fused disco (parallel fed)using 4/0 AL going to a MLO 277v/480v delta Panel, I have 1) a compressor 480v 65A 50hp 2) a compressor 480v 65A 50horse Power 3) a dryer 480v 30A 4) a dust machine 480v 30A 7 hp 5) A crane that is 11.5 A and the lighting that will be 277v 20Amp
Then a 100 amp breaker that will feed a 3phase Transformer 277/480 to 120/208 v 100 amp panel that will only have receptacles on 2 breakers 20 amp.
I need help determining the KVA of the transformer I need.
I can provide more info if needed, Please help me work this out on paper thanks
Sent from my iPad using Tapatalk
