Chancelong
- Wisconsin
- Electrician
I have been working on replacing 277volt T8 fluorescent tubes with ballast bypass LED's in a commercial kitchen. I have slowing been replacing them as they go out, they already had luminaire disconnects installed so power wasn't shut off during ballast removal. I after converting to led I put the new bulbs in and they stayed on for 10 seconds then both went out, then every other light on that circuit, and a few on another circuit went out. Pulled the light apart and it had 480v at the disconnect with no tripped breakers. I checked another light that went out at the same time and it also had 480v across the switch leg and neutral. Knowing that multiple circuits feed this area, with a possible shared neutral, could another ballast be back feeding this neutral and the ballast I removed, somehow caused the other lights to receive 480 volts?
