- Bremerton, Washington
- Master Electrician
OK, a question from a student. wonders why a 277 volt ballast - neutral and hot works (for ten years) on a 240 volt supply. I said the neutral is not a neutral, the ballast does not care about polarity, but the 277 volt ballast works on the lower voltage, of course it may not have the same mA output to the lamps.
What says the forum?
