Good afternoon,
We are working on a assisted living facility. We are using PTAC units in the living units which come standard with a nema 6-15/20 receptacle. We have the option of running the PTAC units at 277 (or) running them at 208.
I am just worried about having 277v inside of dwelling type unit where people may or may not be mentally correct. Is there some type of locking mechanism that can go over the receptacle or should I just go with the 208?
- If we use 208 then ALL the load will have to be carried by the transformers increasing the size of them significantly throughout the whole building and we also only be feeding one per circuit breaker.
- If we use 277 then we can eliminate or decrease the size of the transformers and feed multiple units with a single breaker so this would be the IDEAL way to go.
