If 277V color coded wiring has been installed already, can the conductors be tagged at the termination points to indicate 120V wiring? This way new wires do not have to be pulled.
The wise butted answer is a question... What is 277V color coded wire? :lol: The more serious answer is, I know what you mean, and since the code doesn't actually dictate the colors of the phases, just that they have to be constant, and it doesn't require the marking to be along the entire length of the wire, except for grounding and grounded wires...
Yes you can identify wires that are not white, grey or green to indicate a different color.
BOY, brown, orange, yellow. I know you know what I meant too. The key word I take away from it is "constant", would this re-tagging be constant? For instance, the situation is that 120V circuits have been pulled using BRB, blue, red, black. 277V circuits have been pulled using BOY coloring. There is one circuit that should be 120V except it has BOY coloring. Can this circuit be identified at the ends by BRB tagging so that BOY conductors do not have to be removed and replaced?
Why not use a labeler and label the now 120 volt conductors "120 volts" ?
That sounds like the easiest. Is it allowed in this case?
