EL-Mech-Tech
- USA
- Electro Mechanical Tech
I was replacing some Metal-halide fixtures with new LED Fixtures. They were hard wired, but I could not turn off breaker. They had a separate light switch, so I turned it off there. I checked for voltage on the switched Hot wire (BLK) to ground and it read 277v, turn the switch on it is 0v. The only thing I can think of, that would cause those readings, were if the hot wire is actually Neutral (WHT).
I thought it may have been reverse in a junction box when the lights were install but all is correct. The wires are in FMC and go from this room through two others above drop ceilings, then to an electrical room. I checked the breaker box and it is wired correct there.
I have some colleges that thought a three way switch would get these readings, I did not agree but I checked anyway and the switch is not a 3-way.
Am I correct in my thinking? Or is there something I am missing.
Thanks
Thanks
