The Great Sarducci
- Detroit, MI. USA
Hey all,
I'm currently in the process of designing a 480V enclosure, which contains several heat-generating components (motor VFD drives, motor contactors, etc.). Long story short, the enclosure needs cooling; and am therefore going to be putting a couple of fans on the door. One of my co-workers said that he thought that I should go with a 230V/1PH unit. However my thoughts were against this because this would require installing a transformer. We are limited on space for fuses, so although I could get a 480V/3PH unit, it's going to be hard to do. So what I then suggested was finding a fan that would run on one leg of 480 as a 277V fan motor. Whether or not anyone sells one, I have yet to look into. But on to the reason for my post... As soon as I suggested a 277V unit, my co-worker immediately came back with; "Oh..you can't do that. You're never allowed to have single phases over 150V to ground as it's own circuit inside of an enclosure". This at first puzzled me a bit because I am more than familiar with 277V lighting. But he explained to me that 277 is okay only when run outside of a panel, but inside a panel is a big no no because code will not allow it due to it being greater than 150V to GND. Is this actually true, or a load of bull? Also, I'd like to add that I'm only concerned with low-voltage (600V and lower) applications. I know that obviously no such rule would ever apply to medium voltage panels/enclosures.
