topend
- Parma, Ohio
I was called to check the grounding conductor when a plumber started to remove the ground clamp at the water main, so he could replace the main shut-off valve, and noticed some arcing. I removed the grounding conductor (there was indeed arcing), and discovered there was less than 2v on the grounding conductor. Is this a hazardous situation?
Also, the customer says his lights are now flickering, and has had two lamps and two surge suppressors die since I left.
HELP!
Thanks in advance.
HELP!
Thanks in advance.
