Hi. My first post here. I have C-10 here in California (LADWP area), however I don't do much of, if any, high voltage stuff. I do low voltage. Now I'm working on own property, some improvements, one of them being updating electrical.
What I have is one service feeding two meters with main disconnects outside and two panels (sub panels), one inside each unit. Units are really small, 300 and 500 square feet. I need to redo everything. I have few questions just to make sure I don't screw up anything.
1. Two grounding rods 8 feet apart, #6 GEC (THHN stranded copper as I will be pulling it trough EMT and flex, continuous from end to end), not bonded to the water line as everything is redone with PEX. I assume that I can use the same rods for both units.
2. Thinking of going with 2AWG feeder to inside panel. 1AWG if really necessary. On smaller unit that is little bit further I could downsize main breaker to 80A-90A just to keep smaller AWG wire.
Does above sound right?
