2x3 metal stud wiring
taggart
New User
Seattle
Systems Administrator
I am working on refinishing a basement and am doing the framing with 2x3 steel studs and I have some code questions.
I understand that because the studs are only 2.5" thick, one concern is meeting the requirement of being 1.25" away from the face of the stud.
I read in this post that a common way of solving this is to use MC cable to avoid the 1.25" requirement. If I do that, am I also then required to use metal wall boxes for bonding?
I have a metal stud punch and plastic grommets and saw some suggestions to use GB multi-cable staples for vertical support.
Most of my framing is on exterior walls (against foundation with XPS insulation). Could I use NM cable and somehow secure it to the "back" of the grommet to ensure it's 1.25" away? Or use a colorado jim somehow? Or route the cables behind the studs?(but how to properly secure them?) or a nail guard?(might affect drywall?)
Some of my framing is internal walls, I guess I'm more constrained there.
I'm not so worried about materials cost or time, I just want to do it right and pass inspection.
What boxes do you like for 2x3 metal studs?
Any other words of wisdom?
Thanks
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
