Hi All,
I have a job replacing fluorescent fixtures with LED 2x4 fixtures. I know this subject has been posted regarding running new wire. I am doing a fixture replacement only. Wiring is already installed. Probably around mid 90’s. The wiring is NM above an acoustical ceiling in a commercial building. It’s a private bar and a hall they rent out. I understand this is not code compliant today. If I am not mistaken it was allowed when it was installed. The entire building is NM except the exposed areas. So I am woundering if the MN can stay and just swap out the fixtures since the wiring is existing. Any opinion?
Jim
Jim
