Fishin-trician
- So Flo
cost per fixture to swap mag. ballasts to electronic, relamp with t8s' and labor, on 8ft ceilings. Just curious to see what others charge?
It pays to do all that work?
What's up with the pcb ballasts? Is it the whole disposal issue?
The government seems to think so. We're doing a retrofit right now in a library and also adding occupancy sensors as well.
Couldn't say what the labor rate was figured at though per fixture. If the ballasts are pcb type, you're really going to have your work cut out for you.
For disposal, I use a company that picks up the fixtures, ballasts and lamps from the job site. All I have to do is stack them on pallets and wrap shrink tape around them. They charge by the pound, and I believe it's about $5 per ballast IF it has PCBs.
All of the above costs are charged to the customer. Not my expense.
It's a piece of cake, although it does have a lot of crumbs!
How do you know if the ballasts have PCBs?
