hurk27
- Portage, Indiana NEC: 2008
have a job that I'm in the process of bidding and I need some in put on which would be the best/least costly way to go.
I was call to do some cleaning up of some code violations at a high school on 2 irrigation pump systems and found many other problems.
First I'll post a link to a satellite image of the site and then explain what I found:
Image from above of high school athletic fields
You can zoom in or out.
First the green looking roof building (main maintenance building) at the entrance to the ball fields has a 800 amp 277/480 volt I-Line Square D distribution panel.
From this panel a 100 amp 480v single phase feeder runs across this building to a two space panel with a two pole (240 volt rated)
