I have the 1948 American Electricians Handbook, Sixth Edition, open in front of me. On page 1228, in Division 9, #44 is a table titled
Properties of Flexible Tubing or Loom. The so-called 3/8" loom has:
- inside diameter of 3/8"
- outside diameter of 21/32"
- 250 feet per coil
- largest wire it can be used for is #12 (that would be R, RW, RH, RHW, etc. - old rubber insulated 1900s wire)
- weight of 75 lbs per 1000 feet
NM, as a cable, wasn't developed for normal use until the late Teens or the 1920s.
Loom and the Knob & Tube method predates 3 phase (Tesla & Westinghouse at Niagra Falls in the 1890s).
This connector, in its early
non-die cast form, predates NM, IMO, and would have been referenced to things like 3/8" loom.
Again, quoting from the 6th Ed. American Electricians Handbook:
When metal outlet boxes or switch boxes are used, flexible tubing is required from the last porcelain support, extending into the outlet box at least 1 in. and held in place by an approved fitting such as a universal bushing or a clamp.
While most K&T installers didn't squander the labor to install the NM cable clamp above, in favor of materials requiring less labor, I'll just bet that this lowly 3/8" cable clamp has its creation for K&T or other methods much older than NM.
