Pressure
 - Lawrence, KS
 - Design Engineer
I am combining 3 SMA 5.0-US Inverter outputs onto a 100A 240 Delta 3phase Combiner Panel.  All inverters output 21A.  I will have Inverter 1 output on phase A and B, Inverter 2 output on phase B and C, and Inverter 3 output on phase A and C.  All inverters will have a 30A OCPD.
I am in need of assistance with the calcs for the combined output for my Fused disconnect and Tap size.
Not sure how I got to this, but I think I will use #4 THWN-2 CU with a #8 EGC. A 60A Fusible NEMA 3R 240V 3phase disconnect with 60A Fuses. There will be a production meter, but I will carry on with the #4 CU for my current carrying conductors #8 EGC and from the disconnect have a #6 GEC Bonded directly to the Existing Grounding Electrode.
I want to show the calcs for this in my PS. How did I do this for the disconnect, fuse and wire size?
