3" Core Hole
mkgrady
Massachusetts
I'm installing some floor outlets in an existing concrete floor in an office. This Poke-thru floor outlet made by Wiremold is advertised as fitting a 3" hole turns out to actually need a hole that is between 3-1/16 and 3-1/8". I thought just using a 3" core bit would do it. I don't want to just use a 3" bit and hope the actual hole meets the above limits. So my question is, do I need to get a special core bit for this? Or do 3" core bits generally make a hole a little larger. Seems crazy that the tolerances are so limited.
You should be good with a 3” hole.
That's my first thought, but, Man! you'd think it's GOT to be for the standard 3" saw, right ?!?!?! right?!?!?!
That's what I'm thinking. Why would the manufacturer design a requirement that seems so out of the norm. I'm stumped because core drill bits at 3" are very common when compared to 3-1/16 to 3-1/8". I don't understand why they would design the outlet box that way. It makes me think that a 3" core bit probably makes a hole that falls within the tolerance. I just wish I could get a consensus on that thought.
Wait, this is one of those sites where we read the instructions? :huh:
Oddly, we need a 6-3/8" hole saw to install 6" recessed lights. Hence why I seconded the hesitation for confirmation.
Nope. Round simplex outlet floor boxes we set in wood floors often have an odd size, and going even an 1/8" over makes for an extremely sloppy fit. An 1/8" under, well, it doesn't fit at all.
This is definitely a case of "measure twice, cut once". You may even want to drill a scrap cinder block or the like with the bit you intend to use and dry fit the receptacle before you drill the real thing.
+1 on not just drilling this and hoping it fits ok.
After much hair pulling, I got a whole set of hole saws from about 1" up to 4" by eighths. When I install something, I don't ever trust nominal dimensions. I use a set of calipers to measure the part, then the same calipers to measure across the TEETH of the holesaw, which will determine the finished hole size.
For a core drill, you may want to do a test drill instead. The teeth don't have such a regular set and the cut swarf probably makes for a larger hole as it rubs around during drilling.
Another hole saw (not core drill) trick for when you goof too small: The larger hole saw threads are a standard size, I think maybe 5/8x18 TPI (fine thread). If you buy a bolt and a couple jam nuts, you can cut the head off and thread both holesaws onto it spaced by a jam nut. Then the goof holesaw will center the larger one for the re-cut.
If 5/8 doesn't fit your drill, you can turn it down in diameter by chucking the threaded end into a drill press, turning it on, and taking an angle grinder to the shank until it fits. Or use a lathe, but that would be a whole nother forum :D
Often people in the trade will call the core bit size based on the size of the conduit being installed. Typically a 3" conduit is installed using a core bit that is actually 3.5".
