DanZ
I had an odd question from an engineer the other day, and I couldn't answer it. In a 3 lamp linear fluorescent light fixture, with a single ballast, can you remove a lamp to make it a "2 lamp fixture" and still have it work?
This should be indicated on the ballast label or accompanying documentation.DanZ said:can you remove a lamp to make it a "2 lamp fixture" and still have it work?
Really? I didn't know that! These were existing light fixtures that the tenant wanted to reuse, and the engineer was a little worried when I said we could just take a lamp out and make them a "2 lamp fixture" to pass energy code.:wink:LarryFine said:This should be indicated on the ballast label or accompanying documentation.
I know, I know. It should reflect the maximum allowed wattage of the fixture, not what I put in it. But I haven't had any complaints yet!:wink:Bigrig said:If you are talking about the ASHRAE 90.1 energy code please remember the wattage calculations would be based on how many watts the ballast uses, not just the lamps. I am not sure what effect removing a lamp would have on ballast draw.
Well, I don't believe there's anything in the code requiring wires to have specific colors, so I don't think you actually need to. Although changing wire color in the middle of a run seems like a bad idea to me.lbernard said:When wiring fluorescent fixtures in tandem (master/slave) does the whip to the slave fixture have to maintain the ballast wire color?
You need to be asking the manufacturer this question... and if they acknowledged the contradiction, saying it is ok for blue wires to exit to the slave fixture, request their resolution in document form!lbernard said:the problem is that the whips (13,000) all came from the factory with blue wires. The ballast manufacturer specifies that in tandem wiring, the blue ballast wires must remain in the fixture with the ballast.
