techniphase
- redondo beach, ca.
new to this fuse reducer thing,
i installed a 200 amp 3 phase fused meter main. ide like to install a 100 amp sub off this main. 1. to save on wire and conduit size and 2. eaze of pulling wire in.
can i use fuse reducers in this situation? is this what they are used for? ..if not, any other ideas to do this without a transformer?
thanjks
hans
f.y.i.....the load from sub panel might be 50 amps tops, also, its about 130 ft from the main outside , same building attach.
had to d0 120 /208 because of availability from poco at the pole...ggrrr
thanjks
hans
