JacksonburgFarmer
- Butler County Ohio
Kinda goin out on a limb here.....this is probobaly more utility issue, and I dont know much about utility stuff so....
One of our customers (local grain elevator) has a 3 phase 230v highleg service. The highleg (or wildleg as customer calls it) runs around 190 to 200 volts phase to ground. the other legs are 230v phase to phase, or 115 phase to ground.
The utility line on the road has 3 lines (I belive 2 hot and 1 nuetral?) I do know that it is not true 3 phase, and they are doing something with transformers to produce the three phase off of two phases.....clear as mud?
Now the main question....supposedly, one of the POCO lineman told the customer that "a electrician could balance this system for you" So....customer asks me to look into this.....Any ideas??? I do know another previous EC told the customer it couldnt be done without having true 3 phase from the POCO, and that is my inclination also.....
Any ideas??? could someone explain to me how this transformer configuration works??? Thanks in advance....
