V02maxed
- Plymouth, WI
- Industrial Journeyman Electrician
I'm looking for any suggestions or input. I have several small conveyors in our plant that use 120v to power an AB Powerflex 523 VFD to run a 3 phase motor 230v. The issue is we are in a washdown facility and most of our 120v receptacles are GFI in the production rooms. The conveyor will trip a GFI almost immediately on any GFI outlet we try, with any of the conveyors.
We use Hubble 20amp GFI outlets.
Has anyone run into this before and does anyone have any methods for avoiding this nuance tripping? We are going to try a line conditioner from Isatrol in the panel with the VFD but haven't yet. We use VFD high voltage motor cable with shielding following AB wiring/grounding instructions.
Any ideas would be great. Thanks
