I'm hooking up a CNC machine, along with a vacuum pump (100a breaker w/mechanical disconnect, 2 gauge). The service is 240v B Phase Grounded (3 wire, no neutral). I've wired other machines on these same panels with great success, but never something as finicky as a CNC can be with voltages, so I decided to check the line-line and line-ground voltages. 240 v across all line-line, b phase to ground is reading 0v which is normal, but A and C phase read 30 volts to ground.
Does this seem awkward or is the line-line voltage the important factor in equipment wired for 240v 3 phase?
Thanks for any help.
