I am doing a job at a church that is fed with a 240 Delta 3 phase 4 wire service. I am installing power for 9 -240 volt single phase A/C units. There is an existing 175 amp feeder that is 3 phase 3 wire that I want to use. Now I know the code requires a neutral at all service equipment on a grounded system but is it necessary for me to bring a neutral to a feeder panel if I don't need any neutral connections? Can I use a 3 phase 4 wire panel with a ground bar only and remove the neutral?
