jking1991
- Bristol, TN
- Electrical Engineer
I have quantity 4, 3 phase induction motors with the following nameplate specs:
50Hz
380V
4.80A
3 HP
2.2kW
S.F.: 1.0
Nom. Efficiency: 87.5
Min. Efficiency: 85.5
The issue is that the power supply at the site is 3 phase 480V, 50Hz.
Would a 3 phase transformer 480V/50Hz primary and 380V/50Hz secondary be our best solution?
Another potential issue is that the 3 phase 480V, 50Hz power supply is only capable of 15A, so approx. 12.5kVA. The 4 motors together will need 12.7kVA which allows for no safety margin. Is the only solution a larger power supply?
Thank you!
50Hz
380V
4.80A
3 HP
2.2kW
S.F.: 1.0
Thank you!
