harborrick
- Irvine California
I replace a 600 amp three phase 4 wire 208 V sub panel with the main breaker. It is being fed from a 600 amp three phase 4 wire panel board
There was no ground wire running through the conduit and not sure it is rigid all the way through but I assume it is
All the conduit have ground bushings which link together and go to the neutral buss. I would assume to not bond the ground to the neutral buss. The ground bushing wire should just go to ground buss.
Can you direct me to the codebook in this matter please thank you in advance
