transman2
- Brooklet,Ga.
If you have multible buildings with sub-panels at each, but an equipment grounding conductor was not run with the feeder, can you use a continous water piping system that feeds multible buildings as the grounding conductor if you bond from the water pipe at each building to the building sub-panel grounding terminal bar and by this means, keep the grounded and grounding seperate with the exception of the source or first means being bonded together.
