william_87
New member
- Naples, FL US
I am working on a commercial building, and planning a service upgrade from a 400amp delta system with phase-b grounded (high-leg) to an 800 amp system. While doing this upgrade I will also be doing some panel additions and change arounds within the building.. This may be a bit naive, but I this is the first time working with a high-leg system and just wanted to double check a couple concerns before proceeding
1) does this system work like a standard ungrounded 3-phase system when using 3-pole breaker for equiptment
2) Is there anything else I should be aware of besides avoiding phase-b when doing standard 120v connections
3) Can the wild leg be used when doing a 2-pole breaker for 240v single phase applications.
Again I'm new to the delta grounded systems so I apologize if these are dumb questions
