crowemag62
- Whately, Ma. United States
We are currently looking for a solution to a ground fault issue with portable 3-phase 120/208 vac equipment. This equipment will not normally have a balanced load since 1 phase of the 3 phases is used for the control circuit and a seperate 120 vac utility outlet. We are looking into 3 phase GFCI breakers but we are not sure if the unbalance will cause nuisance tripping of the GFCI breaker.
