3 phase GFI Breaker for commercial pool pump
gojoeba
Any idea where to get a Murray Plug On 30 Amp 3 phase GFI Circuit Breaker?
I see bolt on options around but no plug on.
I didn't even know Murray (Siemens) had any 3 phase equipment unless you have a really old (pre- Crouse Hinds) panel. Siemens marketed the Murray line as residential. I also don't think I have ever seen bolt in Murray breakers.
It's kind of a moot point anyway. Murray circuit breakers were discontinued by Siemens last year. The rest of the Murray line will be discontinued this year. Siemens has a cross reference chart you can show inspectors if questioned that Siemens breakers are the replacement for Murray.
I just looked up the cross reference chart and they do list Murray 3 pole breakers so apparently they did have 3 phase equipment. They don't show any 3 pole GFCI's.
I was installing quite a bit of Crouse Hinds equipment in residential projects before Siemens acquired the line. After that the supply house I was getting the equipment from switched to a different manufacture so I never really followed what was happening with Murray. Siemens dumped all of the original Murray products after the acquisition and just marked their own equipment with the Murray name.
I use Siemens for pretty much all my three phase loadcenters and true panelboards. I dont recall ever using a Murray loadcenter. I knew there was three pole murray stuff because a few times in a pinch I used a three pole murray if they were out of the siemens one. But I didnt know they discontinued Murray recently.
Don't know what Code cycle is applicable and can't say about 2020 but prior Codes do not require GFCI on 3 phase pumps.
