So I understand that a 9 lead motor is basically a 12 lead motor but 10,11,12 are generally tied internally so you only have 9 leads coming out of the motor. That being said I am wondering if most of these motors contain 12 coils in the stator since they 90% of them are dual voltage. The reason I ask Is in general when you draw a wye or a delta you on paper you generally have six windings, but it doesn't really show you how many coils but generally a winding is made up of 2 coils from what I understand. Also if it was only 9 coils in the stator I don't believe you could have dual voltage because when you try and put the windings in parallel it would be uneven. I would assume a 9 coil would have to be either just high or just low voltage based on what I understand if anyone has any insight, I would be happy to hear it. However I would also believe if you had a 6 lead motor with 6 coils you would be able to go delta for low voltage and wye for high voltage.
