in a recent nec forum discussion,someone said "technically you couldn't use a 3 ph panel on single ph service ".i understand the concept of not using something unless it's listed for the job you're doing. i have a customer who owns a storage bldg. that was previosly a lumber yard.he hopes by switching back to single ph , he can reduce the minimum monthly charge by the power co. i would like to change out the meter base,re-use the same mast,panel(which already has 120volt lts and recepts).i would just re-arrange breakers to land on phases that have power.it would save money on cost of panel and labor.would you guys go along with this from an inspectors standpoint?
