JknSD
- the west coast
I have a pump house that has no problems but the voltage/amperage is a mystery to me.
The voltage reads as follows
A to Ground, 480
B to ground, Zero
C to ground, 480.
A to C, 480
A to B 480
B to C 480
The current read as follows under load.
A 18.0
B 18.2
C 18
The utility has verified that it is fed correctly.
In a 3 phase how can A to C be the same as the nominal voltage?
I suspect the B phase slight increase in current comes from the step down trans for the control voltage.
What phase configuration am I looking at?
Any help would be great.
Thanks
A to Ground, 480
B to ground, Zero
C to ground, 480.
A to C, 480
A to B 480
B to C 480
A 18.0
B 18.2
C 18
Thanks
