3 phase to single loadcenter
killer76
I have an application were a supplier has several single phase loadcenter, these are exp proof units
they would like to use with incoming power 208 3 phase,
any suggestion on how to salvage the loadcenters
and still use the loadcenters
would a distribution block and use only 2 legs with the ground be allowable
LarryFine
Henrico County, VA
Electrical Contractor
Basically, yes. Connect each panel to two legs and the neutral (if any of your loads are line-to-neutral), either A-B, B-C, C-A, etc., or A-B, C-A, B-C, etc.
A single large 3-phase distribution panel with 2-pole breakers will satisfy this, and maybe be better than just splicing them. Try for phase-load balancing.
