U-tube-bender
- South Jersey
I'm combining 2- 100amp panels into 1 -200amp and moving it 20' futher into the building. They're both single phase, but there is also a 3phase disconnect for A/C that needs to get moved in. I know I have to install at least a 200 amp disconnect on the exterior now because I'm moving further into the building. Would I use a 3phase disconnect or just a single phase with a separate disconnect for the A/C and only use the third leg to feed the A/C disconnect? Any suggestions?:-?
