fastline
- midwest usa
- Engineer
We have a 75KVA ventilated dry transformer that needs set temporarily. It will supply 2 machines for a bit until separate transformers and load center are installed.
The primary per the 75KVA, will need protected at 90A/480V. Because the secondary side will feed two machines, there is no intention to run both machines at the same time right now. However, I want to ensure the transformer is well protected and I would prefer to have secondary current protection but with two machines connected, that is really not possible without a load center. Is primary protection plenty sufficient?
As well, we will probably need to install this transformer outdoors. We intend to shield it from radiant sun heating and weather with a small roof but want to ensure that is sufficient?
This is an Acme brand floor mount transformer if that helps.
Obviously wiring will be sized appropriate to the loads.
