3 phase transformer feeding with single phase
Shockedby277v
Michigan
What I have is a 480v to 208/120v 3 phase transformer I am feeding for temp power but only have 480v single phase to feed it with. Is there a way I can make this work?
Thanks
Thanks
No. What is your logic. What do you expect that you will end up with on the secondary? You certainly will not get 3ph.
I was trying to achieve 208/120v single phase. I got it though. I basically removed one of the phases in the transformer to make it happen. My trailer is now fed and have power. Yeah!
Thanks
Great! I'm glad that it worked our you. A different way to skin a cat.
Thanks
Thanks
what did you remove? Most single unit transformers are wound on a common core and about the most you will do is insulate unneeded leads.
