The basic formula for 3 phase balanced power is pretty straightforward, I(line) * V(line to line) * sqrt(3) * Power Factor.
It gets trickier with an unbalanced delta load. I have a situation where the line currents are not all equal, the line voltages are not all equal, and the power factors (defined as the phase relationship between the voltage and current on one wire) are not all equal. It is running a big delta connected motor(a chiller), which probably has a couple of smaller loads connected open jaw or single phase(some oil pumps, jacket heaters, and miscellaneous stuff). There is no neutral connection.
Given the situation above, how does one calculate the total power accurately?
