johnjohnls.js
- US
On a 120/208 3 phase panel im seeing 145 on A. 119 on B. And 95 on C. Any ideas on why?
Sent from my LGMP260 using Tapatalk
Duh ! My error ! I didn't read the heading closely enough and thought those were ampere readings.I wouldn’t think that was normal at all, unless having a compromised neutral is normal.
Is that line to neutral or line to ground voltages?On a 120/208 3 phase panel im seeing 145 on A. 119 on B. And 95 on C. Any ideas on why?
And I was wondering - if the numbers were Volts or AmpsIs that line to neutral or line to ground voltages?
yep - me as wellaugie said:Duh ! My error ! I didn't read the heading closely enough and thought those were ampere readings.
Sure it is 120/208 and not 120/240? ....
Probably most likely lost neutral. Lost phase can be regenerated by motors, won't be 100% of what it initially was but should still have reasonably close to 120 volts to neutral on both the remaining good lines.I was curious, so I graphed it - low tech, pen and straight edge on 1/10" paper.
I looks like 208/120 with the neutral displaced ~ 35 volts.
