I have a 3 phase delta high leg service on a residence in texas. I am changing the service. I want to use a three phase meterbase and feed that into a single phase panel box. I want to install a 3 phase fused disconnect next to the panel box. I want to take the high leg and run it directly from the panel box to the three phase fused disconnect without using a three phase breaker since it is a single phase panel box. Then take the other two phases from a 2 pole breaker in the panel box and feed them to the same 3 phase fused disconnect. That circuit would be for the outdoor a/c. Any problems?
