I came across an RO plant with is main distribution connected to the secondary side of a transformer that is a wye seconday but the neutral is not connected, only the three phases and equipment grounding conductor. Is this acceptable according to the NEC?
The load is predominantly pumps for the plant but their are a number of 120v circuits for house lighting and control equipment.
In addition to this an upgrade is being done and the electrician is proposing to connect from a breaker in the main distribution panel to a transformer that is primary delta-secondary-wye and then use a neutral to a panel taking care of house load.
Is the wye connection allowed according to NEC without the neutral and are their any hazards to connecting another transformer to this system?
