Richardh247
- Paris, TX
Hi all,
It has been a long time since I have had to do any real engineering type stuff: as a foreman, we had prints and engineers that determined for us much of what I have been asked to calculate for this job. I'm confident, but I have always thought that running things through others is what sets apart those that just do a job from those that care about the job they are doing.
A little background:
I began in commercial electric back in 1993 and had a nasty fall in 2001 that put me out of work for a long time. After twelve years of basically doing little to nothing I got sober and re-entered the electrical trade as a small contractor several years ago. My company has grown exponentially over the last many months and was recently asked to do a large commercial/industrial project that I feel like we are ready for. The issue is that, typical of small-town sole-owner thinking, the owner of the plant has no prints or calculations drawn up to bid on - those have also fallen in my lap and, while I know we can do the work itself, I've been a bit vexed on the gear and would appreciate someone taking a look at what I have derived for the service.
The job calls for a 600A, 480V main (3-phase) service that will then feed a wye-wye xfmr to juice up EITHER a 240V single phase service or a 208V 3-phase service. The owner doesn't know which one he wants, so I have planned for the bigger demand of the 3-phase 208V. He states, and mind you that this is a direct quote, "I want room for expansion but I don't know how far I will take that." Sigh. The only certainties I currently have are 10 wall packs, 13 T-5 5-lamp Hi-Bays and a few receptacles. That's not much to go on, especially for a xfmr.
Given the ambiguity of the job, I decided on a 200A 3-phase low volt service. Lights are all 277V, so it seems really silly to have ten receps on a 200A 208V panel.
My plan is to run parallel 300's with a #2 bond. 75-degree lugs should then give me 285(2) = 570, then next size up to 600A. The run to the primary is 125'.
Not having any idea what the end load on the xfmr is going to be, or even if he will want single- or 3-phase low volt, I went with 3-phase and came up with a 75 KVA dry-type xfmr. That's a lot of amperage on the supply side, but with no known demand except for the ten or so receptacles I was afraid of a 50 being insufficient if he decided on the 3-phase.
I dunno... this looks both right and way over-sized to me just thinking back on my experience.
Anyone want to opine? Maybe give me something I haven't thought of to go read on and research?
