I am running into a few situations where I need to provide disconnecting means for 3, 120v 20a circuits.
I found a 30a rated 3-pole toggle motor switch(looks like it's small enough to fit in a Bell box) I thought would do the trick. Any problem with this? My main clarification was whether each pole was in fact rated at 30 amp? And yes, I will be pulling a separate neutral for each circuit.
thanks
thanks
