3 tank less water heaters dwelling
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
I'm not up on 220 dwelling load calcs. Question just came in from shop about if a demand factor can be applied to the thread title.
Going to review 220 now just look for help from you people that deal with dwelling units for a living.
Thanks
The optional calculation will count these (and most everything else) at 40% nameplate. But 3 electric tankless water heaters is a challenge for any residential service to deal with (and most take 2 or 3 double pole breakers per tankless). You'll most likely be needing a 400A service. These should really be gas fired if you want tankless water heaters. Or put in one central tankless feeding a few smaller (20 to 40 gallon) electric tank type units close to each shower or bathtub.
