mshields
- Boston, MA
I know that you having a ground fault requirement on the generator side as a result of having any breaker in the EPSS being 1000A or more (assuming 480V). My question is, if you have a relatively large utility service that does require ground fault, but owing to the size of your generator, you do not need it on the generator side, THEN you could go with 3 pole ATS's.
In other words iits all about having ground fault on the generator side only.
Is that accurate?
Is that accurate?
