Greg1707
- Alexandria, VA
- Business owner Electrical contractor
Today I replaced a dimmer switch with a 3 way dimmer switch. After installation the switches worked fine for off/on but the dimmer would not dim. when I pushed down on the dimmer it would just turn off. Thinking there was something wrong with the switch I got another out of the truck and installed it. I had the same results. I know I wired it correctly since the on/off function for both switches works fine and I check the common/travellers as well. Only the dimmer does does not dim.
Any ideas?
Any ideas?
